Truck 12 bolt doable?
Old Apr 20, 2005 | 11:52 PM
Pwebbz28's Avatar
Default Truck 12 bolt doable?
I have a chance to grab two 12 bolt (truck) rears for 250 bucks friday. I was going to try and convert them for my T/A by myself. I know the pinion is a little smaller but is that a big concern? Just looking to get a little info from some people about a truck rear and if this is a good idea.
Thanx
Patrick
Old Apr 20, 2005 | 11:59 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
There is a bearing so you can put a car gear into a truck housing. Good luck.
Old Apr 21, 2005 | 12:05 AM
Pwebbz28's Avatar
GREAT!! 3.90's would be a dream. One last question does moser or strange sell the bracket i need for the torque arm?
Old Apr 21, 2005 | 01:34 AM
zrated's Avatar
I'm also curious in this what truck rear would be strong and ideal for a 98 z28. and how hard is it to convert over. Also how would they hold up perform. Is this a bad idea. Dont mean to hijack
Old Apr 22, 2005 | 02:30 AM
zrated's Avatar
Old Apr 22, 2005 | 10:27 AM
mzoomora's Avatar
14 Second Truck Club
I have heard people say that, but have never seen the bearing. The OD of the inner bearing on a car is much larger than a the truck. The bearing ID would be almost the same as the OD to make it fit in the truck housing.
Old Apr 22, 2005 | 03:04 PM
Derek98z's Avatar
does the truck rear even have spring perches? I assume the truck used leafs.
Old Apr 22, 2005 | 11:41 PM
Pwebbz28's Avatar
No it has leaf perches. You just grind everything off of it and weld your stuff from your rear to it. I dont mind staying with the 4.10 gears but the 3.90's would be nice
Old Apr 23, 2005 | 05:52 PM
Valkyn's Avatar
No one makes a tq arm mount for these old rears, you will need to fab one yourself.
By Brett Foote | 2026-06-04 05:00:17
