4.56 in M6
Old Apr 22, 2005 | 08:50 PM
04-ORANGE's Avatar
Default 4.56 in M6
has any one done 4.56 in a m6 car. thinking of doing it any info would be great.
Old Apr 22, 2005 | 09:05 PM
Dragula's Avatar
What's your redline?
Old Apr 22, 2005 | 09:19 PM
BrandonSS's Avatar
Why?! Traction would be... lets just say impossible unless you have some serious slicks with a cake-ton of VHT all over the place. Then after you don finally manage to figure out a way to grab traction out of the hole you would have to shift at what... 25?mph. So in a modded ls1, thats pretty much instantly.
Old Apr 22, 2005 | 09:22 PM
Dragula's Avatar
With a 6000 rpm redline, stock diameter tires, 1 to 2 shift would be at 38 mph
Old Apr 23, 2005 | 12:04 PM
35th SS's Avatar
dont do it on a daily driver though.
Old Apr 24, 2005 | 06:28 PM
Murdock's Avatar
See my posts here:
https://ls1tech.com/forums/gears-axles/229927-daily-driving-w-4-56-gears.html
And here:
https://ls1tech.com/forums/drag-racing-tech/287588-going-4-11s-4-56s-how-much-can-i-pick-up.html
Old Apr 24, 2005 | 06:45 PM
12stones's Avatar
I'd stick with 4:10's. you could kiss traction goodbye, unless you had some serious rubber.
Old Apr 24, 2005 | 07:13 PM
Tranzor's Avatar
If your shift point is around 7k rpms, I can see using that gear... or if you're always using 28" tires. But with a close to stock rev limiter or 26" tires, there's no way I'd go that high numerically.
Even now with me shifting around 6700-6800 rpms, the highest I'd go on my 26" ET Streets is 4.30s.
Old Apr 24, 2005 | 10:11 PM
35th SS's Avatar
I run 28x12.5x15 et streets at the track.
Old Apr 25, 2005 | 11:23 AM
dug's Avatar
dug
Id like to drive around with some 4.88's on 255 M/T dr with an aluminum flywheel. Too much gear for the track but it would be fun as hell on the street.
Old Apr 25, 2005 | 12:20 PM
Derek98z's Avatar
good track gear for a high power, 28" tall tire'd car. Bad street gear. I know a few guys who have ran it locally. One is almost strictly a track car, the other always ran a 28" et street.
Old May 7, 2005 | 05:16 PM
WhiteyLS1's Avatar
im running 4.56s in an m6 car and i like it. i have 255/60/16 bfgs so that may make the difference in traction. not as bad as i thought it would be for a daily driver.
Old May 7, 2005 | 06:44 PM
44mag's Avatar
I just ordered 4.56s. i cant hook on the street with 3.42s. but with slicks and suspension mods it'll work and when it does look out!!!!!!!!
