DIFFY CHOICE: Eaton vs Auburn (Need help quick!)
Only after ordering the Auburn I noticed the Eaton at Summit and I have a ten percent discount so it would end up costing the same as the Auburn. Which should I go with?? Does anyone have any input? I really didn't want to order an auburn but I am just afraid of breaking units with the gears in them.
Anyone!?!? This is kind of an emergency so if anyone could help out quickly, that'd be great! <img src="graemlins/gr_xmas.gif" border="0" alt="[santa]" />
Actually, those worm gears inside the Torsen-Zexel posi are better than the spider gears found in the Auburn type posis. I'd much rather have the Torsen than the Auburn. Not sure on the Eaton, but if it has spider gears I'd avoid it too.
In other words, our rearends just SUCK and there really isn't any good build up for them. Gotta go with the posi that is "less shitty" than the other in this case.
Tony
3 dead Auburns, 1 dead Torsen.
I've got an Auburn now...but I'm not pushing all that much mmmphhh to it.
I'm not buying another 12 bolt...
I think the pinion walking up the ring--due to the damn crush sleeve not staiying put and in shape, leads to alot of these failures with gears. then comes the spider gears disintegrating...
