2.73 to 3.73 gear?
Old May 14, 2005 | 05:46 PM
wc00ac's Avatar
Default 2.73 to 3.73 gear?
What all will have to be changed if I go with 373s? I have read some things about changing the carrier. Where can I find the one I need? Also where is a good place to get the gears and install kit? Thanks for any info!!!!!
Old May 14, 2005 | 06:11 PM
Blacker's Avatar
The carrier will need to be changed or you will need to buy thick gears. Thunder Racing has a gear replacement package on their website. It includes the gears, install kit, gear oil, gear additve and a TA Cover with stud kit for $400. If you use the thick gears, it is $35 more. Then, you will need to change the PCM tuning to accept the new ratio.
Old May 15, 2005 | 01:38 AM
nrayome98TA's Avatar
Yep what Blacker said. I just did 3.73(I highly recommend it to anyone) and went with Richmond thick gear set, no need to change carrier. The Richmonds whine a little but its not bad. My best mod so far.
Old May 15, 2005 | 08:44 AM
wc00ac's Avatar
Which would be better to change the carrier or get the thick gear? Is it better to do one verses the other?
