Rearend noise...need help!
Old Dec 29, 2001 | 01:04 PM
BLUEBYU's Avatar
Default Rearend noise...need help!
I have an oscillating (sp?) noise from the right rear tire area when I am between 20-40 mph. It goes away if I pull up on the parking brake(ie rear brakes only) and when I release the pressure on the handle the noise comes back slowly. I recently replaced the stock rotors w/ Powerslots thinking that should solve it....nope still the same annoying noise. If I fold down the rear seat it gets much more noticeable. Has anybody experienced this? Any help or ideas would be greatly appreciated.
Randy
Old Dec 29, 2001 | 06:11 PM
WILWAXU's Avatar
Default Re: Rearend noise...need help!
LOL... I have the same thing. It's the cables for the parking brake. They are right above the driveshaft. You need to lube then up... I'm gonna try some white lithium grease on mine.
Old Dec 29, 2001 | 07:49 PM
BLUEBYU's Avatar
John, that sounds to easy to be true! But I'll take it and try it. What exactly though are you referring to when you say "lube them up"? The outside of the cable or inside? And how is it being effected by the driveshaft which is internal to the rearend? I'll take a closer look and maybe I can figure it out, but any clarification would be much appreciated.
Thanks again, Randy Hughes <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
Old Dec 29, 2001 | 07:53 PM
BLUEBYU's Avatar
John, must be late....I just realized you said driveshaft not axle.... so you mean exterior of the cable? I'll get the car up and check it out and get some lube out. Does the sound stop because the cable moves under braking pressure?
Randy
Old Dec 30, 2001 | 09:44 AM
BLUEBYU's Avatar
John, guess I am not clear on where or how to lube the brake lines. I looked under the car and found the cables above the drive shaft as you indicated, but could you be more specific on lubing them up. I really appreciate the clarification. Randy <img src="images/icons/confused.gif" border="0">
Old Dec 30, 2001 | 09:59 AM
WILWAXU's Avatar
from under the car... look at the trans/driveshaft tunnel. Find the parking brake line... follow it to the "spliter". That's where the noise comes from. It right before the rear u joint.
Old Dec 30, 2001 | 05:59 PM
BLUEBYU's Avatar
Where do you apply the lube? Thanks...I guess I am ignorant in regard to the brake lines. Why does this happen only to a lucky few. Randy
Old Jan 2, 2002 | 04:49 PM
WILWAXU's Avatar
Hehe... I applied the gease where the cables come together.
