Ford 8.8?
I was wondering if you had any complaints about the conversion itself, versus his poor business practices, sloppy welding, and crappy setup.
Sounds like you don't - too bad he started off giving this conversion such a bad name.
like i said do a search under my name and you will get the full story.
Many people also never got some parts with their rear.
The 8.8 is a great rear-end, Just not the Way Craig built them. So far, my Relocation Brackets are welded out of alignment, The factory spot is crunched too tight for normal Suspension LCA's.
I have been battling Vibration from Day 1 and I said to hell with Craig setting it up. He can't seem to get things right. I believe from the Total Rebuild I just did, that the T/A mount must also be welded off a bit.
Talked to a guy that builds rears, and the bearing pattern is consistant with Pinion angle being off. The 8.8" and the 9" are both sensitive to Pinion angle. Off 3degrees or more and it'll vibrate, Bind, and Put a score pattern in the Pinion bearings. Fricken blows.
I'll have to get an Ajustable T/A to be able to fix this FINNALLy. After 1year and 3 months I have the problems sorted out. He rushed the Welding and didn't square it up right. I'll have to get another rear in the Future and give up on this one for now. OR I'll have to get the Re-location brakets fixed and get an Adjustable T/A. Stuff I was planning on anyways, just not as a Necessity.
