Ultimate Tranny ?
Old Jan 3, 2002 | 05:58 PM
Terry Burger's Avatar
Default Ultimate Tranny ?
I think the ultimate tranny for me would be a TH350 that would accept a stock type LS1 torque converter (leaving the PCM lockup features in place), have a 3.06 1st gear, work with the stock 4L60E shifter, the stock drive shaft, keep the stock speedo, and have shift points that were easily adjustable at the track (fully automatic shifting). Does such a beast exist? I'm not going to give up my 4L60E until I have too, but a bolt in and clean TH350 like that I'd be able to live with. I'd want it so the only trade off I was making was no OD (and some money).
Old Jan 3, 2002 | 06:23 PM
Patrick G's Avatar
LS1 Tech Administrator
Default Re: Ultimate Tranny ?
A tranny like that exists. Many companies can make them for you. Biggest trick is getting the TH350 input shaft re-splined and the clearances changed to accept the newer style LS1 converter.
It might be cheaper to sell your converter and have a conventional lock-up style TH350 converter made similarly to your ST3800 and spare the modification costs to your TH350. Not to be pimping Yank all the time, but they have these exact conversion kits available. If you're looking for a more affordable alternative, companies like Art Carr, TCI, and JW make some killer lock-up TH350s that will do what you're looking for. Jet and FLP might have something too.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 3, 2002 | 06:33 PM
[quote]
<hr></blockquote>
Am I right in assuming if I use my existing LS1 converter that the PCM will still control the converter lockup in 3rd? I don't mind spending $3000 on a setup when I do it, as long as I'm happy with the result.
Also what does the yank tranny tricker do? How much of the TH350 switch over cost is it?
Does yank do a 3.06 1st gear? I only saw a 2.75 on the website.
So the yank TH350 will work with the stock shifter? Can you explain how that works? IE is D = 3rd gear, 3 = 2nd gear, and 2 = 1st gear? I'd want the car setup so I could let my grandma drive it if I wanted too. <img src="gr_images/icons/wink.gif" border="0">
Thanks!
Terry
Old Jan 3, 2002 | 10:36 PM
BIGBOS's Avatar
I don't think the stock shifter will work....I would upgrade no matter what...ratchet... <img src="gr_stretch.gif" border="0">
Old Jan 3, 2002 | 10:55 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
[quote]Originally posted by BIGBOS:
<strong>I don't think the stock shifter will work....I would upgrade no matter what...ratchet... <img src="gr_stretch.gif" border="0"> </strong><hr></blockquote>
The stock shifter worked just fine in my T/A with the TH350.
__________________
Old Jan 4, 2002 | 07:51 AM
No Patience's Avatar
Tranny tricker will trick the computer into thinking the tranny is in neutral and still there (ie 4l60E). This product will help you avoid throwing codes. Plus its all plug and play no additional costs of computer reprogramming and will make the switch back to the stock tranny easier. I'm sure if you can read wiring diagrams you can make your own.
