BMR adjustable Tq arm and moser 12 bolt
I just finished installing my 12 bolt and bmr tq arm. I already had an adjustable panard rod. When I set the car down, the tq are was hitting the trans tunnel, so I adjusted it to the passanger side enough to clear. First, how many people have this same set up and have a clearance issue? 2nd
how can I make sure i have the rear centered?
Thanks
Thanks
well I don't have this setup, but I have had a few buddies have this problem with other TA like the Spohn and BMR tunnel mounted TA's. The way I centered my 12 bolt is used a plumb bob and taped it too the fenders and measured from the end of the axle to the string and adjusted that way, centered it up just fine.
