Is it my rear end?
Thanks
[ January 10, 2002: Message edited by: Round Rock TA ]</p>
<strong>Is it my A$$?
</strong><hr></blockquote>
There are doctors for this type of thing. They are called proctologists. <img src="gr_images/icons/wink.gif" border="0">
Could be that the driveshaft needs to be balanced, or maybe the flexplate got damaged during the 'verter install?
<strong>I have this vibe in my car above 80mph. I also have what seems to be the same vibe at low speeds but only when turning. Could this be my diff. It al started when I put in my 4L70 and TP4000. But I actually think I just feel it more because of the way the 4L70 crossmember and TQ arm mount are. I would like to get this fixed before it goes south. Is it my A$$?
Thanks
[ January 10, 2002: Message edited by: Round Rock TA ]</strong><hr></blockquote>
Yes that's absolutely true.
Vibration is from the torque arm bolting to the crossmember transmitting to the body, instead of the trans which absorbs the vibe. Also you are using a poly bushing with the 4l70E instead of the rubber one. It is a stronger trans, but you have to live with the noise. You could add more insulation.
Leo
