When do you need a Powerglide?
I know two members of this board are going to/planning on backing an LS1 with a 'Glide, so its kinda a relevent question.
J.
I'm not even remotely planning on it, I just wonder when is a Glide better, and when would you actually ET slower with one?
-much bigger converter
-much bigger gear
to have the same as a 3 speed and it also means you really have to rev out first gear pretty high
I am really not sure when a glide would be better. Maybe an all out application with 6.xx gears? It would have to feel pretty sluggish on the street I would think cause the first gear is only like 1.76 or something. so it would be almost like using a 350/400 in 2nd gear to launch or a 4L60E in "2nd gear start"
you just must need a TON of HP/TQ where a 2.XX gear is just too much to launch on?
the TH350 is more efficient because it is lighter and the internal components are lighter thus equating to eating up less hp than a TH400 does
but also, as matt said, a TH350 takes a lot more money that a TH400 to build to hold the same hp level
As with the p/g, it is the lightest of the above 3 trannies mentioned and is also the MOST EXPENSIVE to build because GM never planned on using this transmission for what some people are doing.
Getting a p/g combo setup properly isn't easy and with more time i bet your friend would've found the right combo matt, but we'll never know. Takes time and money and if something works why change it right?
Lastly, as matt said again <img src="gr_images/icons/wink.gif" border="0"> , one of the MAIN reasons people go to a p/g is because they are just making TOO MUCH HP for that 2.XX first gear of a 3 speed. Take for example those SS/O cars in NMRA making close to 1700hp on a little itty bitty true 10" tire. They use p/g's for this very reason and also if you have that much hp on that little of a tire, would you want to deal with 2 violent gear changes or one? <img src="gr_images/icons/wink.gif" border="0">
