howling coming from rear end?
any ideas guys? hopefully that dont involve the ring and pinion being messed up? is it at all possible that its only the bearings?
i guess the worst part is that the guy at the shop told me AFTER the install that there is no warranty. they dont warranty out work when its going to be beaten on, and i have a "race car"
thanks,
anthony
thanks,
anthony
Its probably the gears, maybe the installer
another rear end build, yipee! so many better things i could waste my money on!
I just did.
Anthony,
Just drive the MF'er till it breaks, all the while saving up for a 12bolt. I'll help you with a rear end swap once the beater breaks Trending Topics
99PontTA - Westwood Chevy in Westwood NJ
The car is still under the original factory warrenty, the reasoning they gave me for the continued noise is that since there isnt much in the way of sound deadening material in the back of the car, i will hear any noise. Although i am still skeptical since its only right around 60, and its only under load.... any thoughts?
Odd coincidence, I bought my 99 TA from Key Pont (I'm from Allentown originally) in Dec 2003. During the test drive I had a howling from the rear, and they fixed it before I bought it. They claimed to have swapped the ring, pinion, and posi unit which seemed to fix it. It took them a while, claiming the gears they were getting weren't cut right. The howl was gone for a while, but the driveline is getting a bit noisy now with some howling at speed under load and some other various noises. I admit, my poly tranny bushing and Kirban shifter add to the noise so I'm not all that worried for now. Besides, when the 10-bolt goes...good riddence!!
Joe
