10 bolt
Old Jul 11, 2005 | 01:36 AM
CASHss99's Avatar
Default 10 bolt
hey , now when someone says they blew there rear end, or they say your going to blow your 10 bolt
what does that mean
just blow teh gear up, or rip the hole 10 bolt in half ,, im so lost?
Old Jul 11, 2005 | 02:00 AM
luvmeZ28's Avatar
what does that mean
you can twist/break axles, break/blow spider gears, and shred teeth off the ring gear and/or the pinion. or if its installed wrong, you can grind yours gears down, like im currently doing.
there are alot of things that can happen to a rear end, especially the sissy 7.5 10 bolt.
Old Jul 11, 2005 | 09:10 AM
777's Avatar
777
Yup, I stripped about 6 teeth off of the ring gear and screwed up the pinion gear as well.
Old Jul 14, 2005 | 01:38 AM
CASHss99's Avatar
damn,, people are telling me to build teh 10 bolt like throw sum moser axels in ther and strengthen it up,, can you do that????
Old Jul 14, 2005 | 02:05 AM
luvmeZ28's Avatar
after having to regear my 10 bolt once, and needing to do it again now, i say its not worth modding the 10 bolt. im gonna drive this sucker til it pops, and hope i can save enough for a 12 bolt before then.
Old Jul 14, 2005 | 08:53 AM
NC98Z's Avatar
Ain't it a Bitch! They can build a NOPI RICER where it can run 170 mph in the quarter and Chevy can't keep these 10 bolts together.I'm in the same shape as you with my 2.73's bringing up the rear.Do the 12 bolts or the 9 inchers hold up the best? And what kind of rearend do these 400 hp gto's run?
Old Jul 14, 2005 | 09:35 AM
777's Avatar
777
Do you actually think those ricers are running a stock driveline?
Old Jul 14, 2005 | 10:23 AM
bigman's Avatar
I had a rice mobile and the ammount of front axles and cd joints i had to replace was insane. over 5 grand worth.
Old Jul 16, 2005 | 03:18 AM
CASHss99's Avatar
danm $$
Old Jul 16, 2005 | 06:09 AM
SporkLover's Avatar
My last rice car had stock axles that were able to withstand 500whp abuse, and were cheap to replace.
Dodge did great things with the SRT-4. The 04-05 Cars have the good axles.
Old Jul 16, 2005 | 09:50 AM
JRracing's Avatar
My carrier just broke, it was a torsen unit. I drained the oil and a bunch of chunks fell out of the drain hole. 9" on the way now.
But the new 4.11's were fine.
