Pinion seal question
Old Jul 12, 2005 | 05:43 PM
DreamState23x's Avatar
Default Pinion seal question
I need to change my seal and have to borrow a torque wrench from work, our wrenches are like 10-100 inch lbs 100-150 and so on. Which one do I need to check how much torque it takes to rotate the pinion. what is it around generally. Thanks. and how much of a pain in the butt am I looking at doing this?
Old Jul 15, 2005 | 02:41 AM
No one can help me out here?
Old Jul 15, 2005 | 10:35 AM
LS1s R US's Avatar
Ya have to put about 20 inch pounds on it! But thats with the carrier& ring gear out setting because it will add resistance to the measurement!I always do it that way because of this reason!Doesn't take me to long Guess I've done a few of them tho!
Its a little work and a little time.good luck!
Old Jul 15, 2005 | 11:04 AM
1madss's Avatar
You will need to use either the dial type or maybe a beam type torque wrench. The usuall click type does not work well to set the bearing preload. They also make a little special wrench to do it with, but it's pretty much just a dial torque wrench with low settings. I also use 20 inch pounds.
Old Jul 22, 2005 | 08:17 PM
Thanks for the help.
Old Jul 23, 2005 | 02:45 PM
HBHRacing's Avatar
If all your doing is the seal you don't need the TQ wrench. using this guide and it will get you there without it http://www.mainstreamtopics.com/foru...showtopic=2770
