I have differential problems
Old Jan 14, 2002 | 07:13 PM
8URTANG's Avatar
Default I have differential problems
We noticed at the track that most of the time my car just wanted to spin with the right wheel . Does my diff. need rebuilding , or would a fluid change and some friction modifier help ?
My right tire is slick and the fender is covered in rubber, while the left one is ok and the fender barely has any rubber on it.
Also couldn't that be part of my horrible 60' times ?
TIA guys
Old Jan 14, 2002 | 11:31 PM
MacGyver's Avatar
Default Re: I have differential problems
Sounds like your posi unit has went out. It's possible that a fluid change could help a bit. Take a look at it when you get the cover off. Might be more going on in there than you think.
L8r
Will
Old Jan 14, 2002 | 11:43 PM
8URTANG's Avatar
Is this normal on a car with 49k miles ?
Could be just be one of those things that happen I guess.
When I get the cover off what am I looking for exactly, I don't think these cars have clutches in the diff.'s right ? So what went bad ?
Old Jan 16, 2002 | 02:03 AM
Chris Spiess's Avatar
49K may be a little early, but those difs are not known for their longevity. Depends on how hard you've been on it. Unless you popped for the torsen when you bought the car, the 98s have a clutch pack dif in them.
Old Jan 16, 2002 | 02:12 AM
8URTANG's Avatar
I bought the car with 45k on it, how can I tell if it is the Torsen ?
[quote]Originally posted by spiesscj:
<strong>49K may be a little early, but those difs are not known for their longevity. Depends on how hard you've been on it. Unless you popped for the torsen when you bought the car, the 98s have a clutch pack dif in them.</strong><hr></blockquote>
