Cannot keep this 12 bolt alive
How much HP does the car put to the wheels? Anything less than 600 and I would try to get my money back!
BUY A 9in!!! You could have bought one already with all the money you have wasted on gear sets and installs... Call MOSER and tell them whats going on and bitch them out!!
EDIT: I went back and read that you arent actually breaking all those gear sets.. Just getting noisy as hell. That is a very common thing with 12-Bolts and especially the Moser units. Gomer has the same problem with his..
I did however still sell it and bought a Currie 9in, which I modified for 3 channel abs, in the hopes that it will not make any noise. (fingers crossed)
Ya what he said. The Best V8 Stories One Small Block at Time
Thats what im saying.... just go a full spool....... if its that noisy just turn up the radio....... ha ha
Kyle
You can buy a flying magnet type ring/sensor setup from chassis places like Bickel, Applied Racing, Quartermax, etc. that mounts to your pinion yoke. It's basically like a crank trigger except smaller. Guys use it for monitoring driveshaft speed with their data loggers. You just need to have someone figure out how to convert the electronics. It can't be hard though, both sensors work on the same principle. Just the number of teeth/triggers is different.
of mounting the stock sensor.Now for the 2300 on the 9"? I may have that much in scrap ring and pinions.
But when I'm knee deep in the throttle and banging gears it was quiet which is most important. I bought mine back in Sept. 01.
I now have transplanted it to my 99 Formula which only runs 7.60's in the 1/8th with 1.63 60ft's. its pretty stock except for suspension
The problem that I did just have finally is my clutches in my EATON HD800 posi unit just failed. So I have it apart right now and the R&P look fine but now I have to rebuild the posi.
I'm thinking of swapping over to a DETROIT TRU-TRAC right now and putting a new R&P in it.
