Warped rotors
Old Jan 16, 2002 | 07:07 PM
Chris2000Formula's Avatar
Default Warped rotors
Ok like a lot of you I have warped rotors. I'm still under waranty but I don't want to take it in to the dealer because it would be a big hassle for me to be without my car on a weekday. Can I just take the rotors off and have them turned? Would that work at least for a little while or is it impossible to turn warped rotors?
Thanks in advance for any advice,
Old Jan 16, 2002 | 07:30 PM
2000 Camaro SS's Avatar
Default Re: Warped rotors
Yes you can have them turned and then they should be as good as new. I had to have mine turned on my old 1999 Camaro 2 times. It is not to expensive to get it done.
Old Jan 16, 2002 | 09:11 PM
WeatherGuy's Avatar
Unfortunately, turning the rotors will leave you with the same rotor you had earlier, only thinner. It WILL warp again on you, just a matter of time.
The stock braking power is actually quite good, but the rotor quality is low. I would look at getting a good set of aftermarket rotors if I were you, but it will require forking out the dough.
Old Jan 17, 2002 | 02:20 AM
Judd's Avatar
Had mine warp at around 5K miles, had them turned. Used a torque wrench set at 90 lbs on the lugs. Haven't warped since, it's got 27K on it now. I play quite a bit in the mountains and they do get pretty hot, I've been alot harder on them since the first 5K miles. No lapping sessions or anything like that. Try it, it's worth a try.
[ January 17, 2002: Message edited by: Judd ]</p>
Old Jan 17, 2002 | 05:31 AM
I have 35,000 on my 2000 SS and maybe 24 1/4 miles runs. When in Alaska I did 4 runs in a row at the track my rotors turned glowing red hot and the brake light came on. Now the rotors are blue but not warped. On my 1999 Camaro they were a problem along with my wife's 1999 & also her 2000 Monte Carlo these three cars all had bad rotors. If you turn them the may warp again in time maybe not. If you don't have BIG bucks to drop on good brakes turn them and save for some new ones. I would love a set of Bear brakes but my money tree done died. <img src="gr_sad.gif" border="0">
Old Jan 17, 2002 | 05:43 AM
mitchntx's Avatar
There was a part number change in GM's factory issue rotors mid last year.
I have as set and they have held up well to some "spirited" braking.
Old Jan 17, 2002 | 11:24 AM
Nine Ball's Avatar
LS1Tech Co-Founder
moving to drivetrain/suspension section
Old Jan 18, 2002 | 12:38 AM
Thanks for all the replys. I guess I posted that topic in the wrong forum. I think I'll have them turned and hope they don't warp again. If they do it looks like it will be time to upgrade.
