Zexel Torsion vs. Eaton
I was racing Friday night, and tore up my differential when I accidently left Traction Control on and tried to burn out
I do not want to get a 9" or a 12 bolt at this time due to financial limitations, but I am going from Precision Gear to Richmond 4.10's. I want to go with the stronger posi that SLP offers, but a friend mentioned Eaton. Which one is stronger?
How does one get rid of those weak C-clips?
I am also wishing to upgrade my rear axles, and am looking for recommendations there. I already have a solid pinion spacer to go into it and a TA Cover that pre-loads the bearings. If there is anything else that I am missing, please mention it.
I ran in 91* heat 77% humidity and cut a couple of 2.0's and ran 12.71@112.5 mph on Nitto DR's. With a very strong 10 bolt, what kind of tires can I run?
Thanks ahead of time for all of the information
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
You might want to consider running the Motive 4.10's...I've heard that they run quieter than the Richmond gears. (I have them from motive and they're nice and quiet for the most part).
I also run an eaton posi, but couldn't tell you whether the heavy duty zexel (which I think you are talking about) or the Eaton is stronger.
I know people that have run plenty of 10 second passes using the Eaton and it has held up.
It's not mine! woo hoo!
If you're on financial contraints, just get a used Torsen from someone. Then start saving for a 12 bolt or 9 inch. There is no reason to waste money on that POS 10 bolt. When I blew my Torsen, I put in Richmond 4.10's, TA cover, and hardened cap studs. The ring gear blew about 10k miles later.
If I were in your situation, I'd go cheap and take it easy until you can afford the better rear. If you refuse to do that, go with the Eaton HD (clutch packs are better IMO), run the GM/Motive gears, get a cover and studs. Forget upgrading the axles.
Thanks for the replies.
I have True Duals and it's a weekend car so it is noisy as is. I will take the advice and get the Eaton Posi. I already have the richmond gears, so that is not much of an option. I've got a cover, and a solid pinion spacer. I am not familiar with the hardened cap studs, can you send a link of who sells them, or describe them a little more?
10k miles will last me about two years or so, and by that time I'll have the disposable income for a 9".
I've had Motive Gear and Precision Gear 4.10's. They both started quiet, but they got loud towards their end.
Thanks for the tips.
