Tranny Fluid?
Old Jan 22, 2002 | 01:48 PM
LS1LT1's Avatar
Default Re: Tranny Fluid?
I'm curious too. I've heard discussions both for and against synthetic in the A4, and also if yes, which synthetic to go with: Mobil 1, Redline, Amsoil? <img src="images/icons/confused.gif" border="0">
Old Jan 22, 2002 | 04:03 PM
Chris Spiess's Avatar
My trannys all get synthetic. Premium synthetics have better heat tollerance and live a lot longer in a high heat environment - ie towing and performance applications. For example, AMSOIL's synthetic ATF has an acceptable operating temperature range (~-50*F to 275*F) that exceeds the entire operation range (including the border line range and extreme limits) of common pertroleum based ATF. It also has about 3 times the fluid life of common ATF.
Old Jan 23, 2002 | 12:35 AM
NO CATZZ's Avatar
Default Tranny Fluid?
I am about to install my new torque converter and have a little question about tranny fluid. Is it worth the money to buy synthetic or should I just stick with conventional? If it is worth the money I want to do it when I change converters so that I can change ALL of the fluid. Thanks.
