Same question over and over.
Old Aug 19, 2005 | 12:49 PM
jimmyblue's Avatar
Moderator
T-2R is the Torsen they should have put in. More
gears, more torque biasing capacity and preload
springs so even with one wheel in the air you have
some biasing to the good wheel. Hard to find, but
similar in price to the other little-10-bolt chunks
(available also for some other diffs). I got mine
from Strano.
There is also a T2-HD like SLP and others sell, which
has the beef and somewhat higher torque bias limit
(not quite as high as the T-2R I think) and no preload.
Very slightly lower in price but I would (did) go for
the super supreme.
It's not the best drag racing center section but
there's nothing better for road course / AX I
believe.
It eliminates the one-wheel-peel and pretty much
guarantees you will break something else in the
small pumpkin first. My stock Torsen had put a
whole bunch of shavings down in the soup, by 20K.
That's from it failing to split torque, slipping and
scrubbing the bind-points instead, I think. The
T-2R makes the tires give it up first, instead.
