bad pinion seal??
I know this will lead to problems down the road, but what can it do now? can this cause my pinion to vibrate? I'm sure it will cause the ring/pinion to wear excessively. I have horrible clutch chatter, and that probably made this happen/ or get worse.
Can I change/check the pinion seal myself? I have little knowledge of rear ends, but have done a clutch in my car, so im not completely helpless.
Does the rear end need to be realigned? If so, It will probably be worth getting 3.73's in the near future (too bad I cant afford it).
thanks in advance
Paul
