Shaking over 80mph
Old Aug 22, 2005 | 03:51 PM
SSkeet's Avatar
Default Shaking over 80mph
Recently I got my car all back together, have done a lot to it, and now at 80mph+ i get a bad vibration, not rpm relevant. I can look over and see the passenger seat shaking/vibrating.
I bought a 12bolt from a guy recently on here and he threw in a "1000hp custom driveshaft" that he had made. I am wondering if maybe the driveshaft is what is causing the shaking? Maybe I need to have it balanced?
Any ideas? I am going to put the stock driveshaft back in as soon as I get the chance...
Old Aug 22, 2005 | 04:14 PM
Silas2k's Avatar
ya just balance and rotate tires, maybe alignment if that doesnt fix it... good luck to ya, keep us updated hopefully its not the ds
Old Aug 22, 2005 | 05:58 PM
Mr_president's Avatar
i have the same problem im buying a pst drive shaft look at my thread witch drive shaft dennys racing or carbon fiber.......let me no when you get your prolem fixed
Old Aug 23, 2005 | 11:01 AM
GuitsBoy's Avatar
Try an pop the rear U joint and spin the driveshaft 180 and see if that helps out. Quick and free to try.
Old Aug 23, 2005 | 09:21 PM
seal's Avatar
i'm willing to bet its the ds
Old Aug 29, 2005 | 09:50 AM
SSkeet's Avatar
Well, I noticed 1 thing in particular that MAY be causing it...
After I did the relocation brackets (exactly per instruction), now the rear end is out of square. The left wheel is noticably more forward and the right wheel is noticably more rearward. I wonder if this could be the main culprit?
I think I am going to buy a set of adjustable lower control arms, i think it is a good idea in order to straighten that out anyway.
An other ideas?
Old Aug 29, 2005 | 11:27 AM
RW99's Avatar
I have the 80 mph vibe, although I'd call it minor. See setup details in sig.
I had U joints inspected (OK) and driveshaft replaced (with the LPE DS), but I still have the vibe. It feels like driveline because it is most noticible when I give the car a little gas at that speed. Once I let off the gas, the vibe disappears... although the engine rpm and vehicle speed are virtually the same. Not sure what's causing it. I'm going to a 9" soon, though, and throwing in an adjustable panhard... predict it'll be gone after all that.
Other ideas?
Old Aug 29, 2005 | 12:24 PM
transam1998's Avatar
Default Mine too
I had a vibration on my driveshaft that started at about 110 mph after my 12 bolt install. When I looked at the driveshaft, I have a weight on the front that has been knocked off. Need a balance
Old Aug 29, 2005 | 11:51 PM
RollinSScamaro's Avatar
same prob with my DS.. the yokes aren't; completely inline though.. it is getting fixed soon and hopefullt it goes away.. I think i might save for a CF DS later down the road though.. getting a lot of good feedback on them lately! especially pst!
