4'10's on stock rear end
Old Aug 24, 2005 | 10:14 PM
Starz T/A 17's Avatar
Default 4'10's on stock rear end
Wanted to put 4'10 gears in my car but still have the stock 10 bolt rear end. How much of a chance am I taking of blowing the rearend with the new gears? (I also dont plan to launch past 3 K ) Also my car has a M6 transmission
Old Aug 24, 2005 | 10:23 PM
99hugcam's Avatar
I launched AT 3,000...Broke every tooth off the ring and pinion.
99hugcam's Avatar
Sorry, are you an a4 or m6? If m6, don't do it.
Old Aug 24, 2005 | 11:13 PM
Sorry forgot to add its a M6 tranny
Old Aug 25, 2005 | 07:07 AM
Chris81's Avatar
I leave at 5500+ rpm on BFG's with a stock 10 bolt and 4.10's, no problems.. the key to getting the turd 10 bolt to live is tirespin and clutch slippage.. you can't completely dump the clutch.
best 60' is a 1.75, at 5400 ft DA.
Old Aug 25, 2005 | 07:18 AM
ss1129's Avatar
No you didnt....its right in your first post.
Old Aug 25, 2005 | 07:42 AM
herk01SS's Avatar
I put them in my 95 Z vert on the stock 10 bolt. Dropped 0.4 off my 1/4. Did not have stickies, did not launch above idle and did not fully power shift. I had no problems but this was basically a street car and they were awesome on the street. They were Zoom gears if you wanted to know.
Old Aug 25, 2005 | 07:44 AM
herk01SS's Avatar
By the way I had a six speed and just bolt ons.
Old Aug 25, 2005 | 09:48 AM
I went back and edited it
Old Aug 25, 2005 | 09:50 AM
Thanks for the info, so basically if I dont completely dump the clutch ill be fine
Old Aug 25, 2005 | 09:53 AM
ss1129's Avatar
Ill learn you to make me look stupit.
Old Aug 25, 2005 | 10:10 AM
freakynipples69's Avatar
you can make it last, but chances are it won't. Some people are lucky, others aren't. I say try to save up for a 12bolt.
