Rear End Fluid?
Old Aug 27, 2005 | 03:48 PM
LS1BlackBird99's Avatar
Default Rear End Fluid?
Where can you pick up the fluid already prepared to pour in our rearends without having to mix it yourself? I am looking at replacing my pinion seal next weekend and would like to go ahead and change the fluid because I have lost so much. Any suggestions on what I should use?
Old Aug 27, 2005 | 03:57 PM
00BlackSS's Avatar
advanced auto!!! any auto part store has em!!! gear oil and a 12 or 8oz bottle of posi additve!!
Old Aug 27, 2005 | 04:03 PM
Yea I have seen them there but wasn't sure if there was already one with the posi in it that you dont have to mix. Any brand better then others?
Old Aug 27, 2005 | 06:28 PM
Strokinit383's Avatar
I got valvoline synthetic blend at meijer. I have some friends at the dealership and that is what they recommended. Oh, and dont use posi additive with it.
Old Aug 27, 2005 | 09:40 PM
Why not use the posi additive? I thought that was very important. Also what weight gear oil is required for our cars?
Old Aug 27, 2005 | 09:51 PM
Shadow Assassin's Avatar
I always pick up the GM stuff from the dealer. Had a bad experience with the pre-approved equivalent from other retailer once. Cost me a new rearend that we later learned wasn't even needed (long story .) Maybe others have been luckier and I just got a raw deal. In any event. it's not that bad to get the oil and lubricant from dealer and then mix them yourself. Just be careful with the additive. It stinks like ***.
Old Aug 27, 2005 | 09:53 PM
By the way, the additive is EXTREMELY important.
Don't cut corners here. It's just not worth it.
Old Aug 27, 2005 | 10:16 PM
00BlackSS's Avatar
yes....any gear oil smells like poop!! and additive is key!!!!!!!!!!!!!!
Old Aug 27, 2005 | 10:53 PM
MOE_TAWS6's Avatar
Isn't it like 80/90? or something like that..?
Old Aug 27, 2005 | 11:06 PM
Yes additive is key, if you dont use synthetic fluid. If you use synthetic it isnt needed and has no benefit. This information came from their top technician with over 25 years of experience. I think it was either 85 or 90 weight oil.
Old Aug 28, 2005 | 10:58 AM
Blacker's Avatar
If you have the Torsen Differential and the 1999's do, you can use a synthetic 75W-90 GL-5 Gear Oil. Otherwise, use a 80W-90 GL-5 Dino Gear Oil. LSD Additive is not needed since they do not have clutch packs. They had worm screws and additive is not going to help. I was talking to some tech's at the dealership and they have seen a lot more differential problems since GM went to the Torsen. GM cutting costs again.
Old Aug 28, 2005 | 03:18 PM
Ok, I think I have seen some 75W-90 Mobil synthetic at Autozone. I keep getting mixed answers if I need the LSD additive or not though.
Old Aug 28, 2005 | 03:57 PM
Blacker's Avatar
The dealerships around here don't even stock the LSD Additive. They said they had no need for it and I have to special order it. You can put it in but, it make no difference.
Old Aug 28, 2005 | 04:13 PM
If its synthetic, dont get the additive. If not get it.
Old Aug 28, 2005 | 11:31 PM
DeltaT's Avatar
I'm running Redline 75W-90 Synthetic in my 12-bolt and it's great. They state right on the bottle that no additive is needed.
A side benefit is that my rearend runs 25 degrees cooler with the Redline in it. My friend has an infrared thermometer gun and we did back to back 10 mile runs before and after, with the outside temp within 4 degrees.
26 degree drop after the change.
Jim
Old Aug 29, 2005 | 04:22 PM
Trent's Avatar
I have run in all my previous cars as well as this one Royal Purple 75w90 in the rear. Has the additive. Just buy two quarts and fill till it starts coming out. Should take about 1.75 quarts.
Old Sep 7, 2005 | 04:25 AM
luvmeZ28's Avatar
does anyone stock royal purple or will i have to order it? and just to keep beating it into the ground, if i use RP i wont have to use an extra additive?
