3.42 gears
Old Aug 29, 2005 | 04:15 PM
layz's Avatar
Default 3.42 gears
i bought some 3.42 gears out of a 2000 ss camaro. i have a 2000 z-28 with 2.73. i bought them for $50. i have a part # on the ring is 12 41 26050890 xxx. i am wondering if these will work in my car. the place i bought them they said they will work.any ideas of the part #. is this the thicker series. if they do not work what will i need to get them to work. i do not want to change out carries. somebody throw some info back at me please...
Old Aug 29, 2005 | 06:25 PM
HotRodNeil's Avatar
If they were 3.42 gears from a stock 2000 ss, they're probably series 3. You, however, have a series 2 carrier because of the 2.73. You need this:
USGear (Strange Gear) Part # 01-875373X
which is a thick series 2 which will fit your car.
Someone please verify this. Thanks.
Old Aug 29, 2005 | 11:31 PM
Ouija's Avatar
You sir, are correct! (Except the part # is wrong, gotta change the 373 to a 342 so the right part # is 01-875342X)
Here go read these two threads, I'm too lazy to post the same information a third time today:
https://ls1tech.com/forums/gears-axles/372464-2-73-3-42-do-i-need-different-carrier.html
https://ls1tech.com/forums/showthrea...57#post3417357
Then if you have any more questions, please ask!
In a nutshell:
The gears you bought are useless unless you change carriers. Don't worry, the same thing happened to me, but I sold my gears to someone who could use them for $50!
Old Aug 29, 2005 | 11:46 PM
chicane's Avatar
I'll third that.........
