solid sleeve
Old Sep 1, 2005 | 01:21 PM
SLP4CamaroSS's Avatar
Default solid sleeve
im going to rebuild my rearend with a new posi,gears, and the deluxe ratech kit. how much torque do you put the solid sleeve in same as the crushed one?
Old Sep 1, 2005 | 08:55 PM
anyone know
Old Sep 1, 2005 | 09:19 PM
Hawkcmc's Avatar
Same as a crushed and then check the preaload.
CMC
Old Sep 1, 2005 | 10:19 PM
i been hearing about peopel torque them down by alot
Old Sep 1, 2005 | 11:19 PM
Carter Hays's Avatar
Measure your old crush sleeve. Get your shims right, torque the solid spacer to 125 ft-lbs. check preload. Add or subtract shims as needed. Apply red loctite and torque it down.
Remember bearing preload is different between new/used bearings. I also like to check the total assembly.
On all the ones I have done the solid sleeve seems to cure the leaky seal F-body problem. Crush sleeve, well, the leak shows up again over time.
Get some air tools.
Old Sep 2, 2005 | 12:11 PM
GuitsBoy's Avatar
Get some air tools.
I like this method.
Old Sep 2, 2005 | 03:04 PM
when im doing it is it ok to pm you for help?
Old Sep 2, 2005 | 06:12 PM
Sure, you can. But I can't stress how important the right tools are. (work smarter not harder)
A solid spacer takes a little more work, but worth it IMHO.
If this is your first foray into rebuilding a live-axle rear-end, then this link will let you know what you're getting into.
http://www.fullsizechevy.com/fscu/axletech/
I might not be much help in the next few weeks. We have family wiped out by Katrina headed our way.
