Rear axle gear ratio??
Old 09-02-2005, 10:48 AM
94strokedz's Avatar
Default Rear axle gear ratio??
Is there any way to tell what rear end my car had from the factory using the VIN number?? The service parts identification tag is no longer on my drivers side door. The car is a 94 Z28. How can I tell what rearend it has without the tag? Thanks.
Old 09-02-2005, 12:45 PM
Ragtop 99's Avatar
With the converter locked in 4th gear, what mph are you?
273 = 80 mph
323 = 67 mph
Old 09-02-2005, 02:11 PM
94strokedz's Avatar
Convertor will not lock in fourth, ongoing problem. Locked at what RPM?
Old 09-02-2005, 02:59 PM
1999Z28's Avatar
if you got 3.23s, 2000 rpms is about 67 mph
Old 09-02-2005, 03:31 PM
94strokedz's Avatar
Thanks, I'll go home and see what I got.
Old 09-02-2005, 05:49 PM
Z95m6's Avatar
What does your speedo go to? if you have a 150mph speedo you have 3.23's if you have 2.73's your speedo would only go to 115.
