Redline Synthetic oil with auburn carrier
>Make : pontiac
>Model : firebird
>Year : 1999
>Engine Type :
>Differential Size/Type : 10 bolt auburn carrier
>Issues : brand new carrier from auburn installed
>Recommendations : Auburn recomends on using non snythetic gear oil
>with a fiction modifier...i want to use redline synthetic gear oil
>so the carrier doesn't wear out again...please make a recomendation
>Thank You
Barbara,
Thank you for contacting Red Line Oil, in your 10 bolt differential I
would recommend the 75W90, it would be suitable for use in your
Auburn differential.
Regards, Dave
Red Line Oil
READ IT FROM THE HORSES MOUTH!
>Model : firebird
>Year : 1999
>Engine Type :
>Thank You
Barbara,
Regards, Dave
Red Line Oil
I had the 10-Bolt Auburn Diff in my 02 SS as well. I used Royal Purple Gear Lube
with 2 bottle of additive. This was recommended by SLP as they were the original
installers. As you may know, or not, the Auburn Differential is a little louder than the
Eaton. So they told me to add two bottles of the friction additive and do several
figure 8's in the parking lot and it'll quiet'n it down. He wasn't lying.
