Radio Shack Cheap Fix for Skip Shift?
Someone posted awhile back about installing a 2.2 Kohm resitor(sp)In the skip shift connector, disabling the skip solinoid and keeping the PCM light off. But I can't remember the wattage. 1/2 or 1/4? Does any one know? Thanks to all who respond. <img src="images/icons/confused.gif" border="0">
I used 1/2 watt, haven't had a problem since installed. I believe a low voltage will work, except it cant handle as much heat.
Went there. Lots of info. Thanks That's what I was looking for. <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" /> <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" /> <img src="gr_grin.gif" border="0">
www.installuniversity.com
Worked like a charm. been in there for about 4 months of ABUSE and i haven't ha a problem with the "cheap fix" <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
I did the 2.2k 1/2 watt about a month ago..so far so good...5 resistors for 89 cents...or spend 30 bucks for a plug in...29 bucks saved is almost track fees for a day 8-)
-Dave
-Dave
