Rear Air bag?
Old Feb 16, 2002 | 09:57 PM
SteveD's Avatar
Default Rear Air bag?
How much pressure do you run in your bag when you are not at the track? What pressure do you run at the track? Just installed one and I am trying to get a feeler for what the norm is.
Steve <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Feb 17, 2002 | 05:50 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: Rear Air bag?
I constantly run mine right around 20 psi.
__________________
Old Feb 17, 2002 | 07:14 AM
Raughammer's Avatar
D(irecto)r Pepper
I use 15 pounds.
You need more air if the car is heavier.
15~20 is a good range to work with.
Old Feb 17, 2002 | 08:56 AM
Patrick G's Avatar
LS1 Tech Administrator
Most Stock Eliminator guys run 20-22 lbs.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 17, 2002 | 09:48 AM
StreetStalkerZ's Avatar
I run just a few pounds of air in the bag on the streets and 18-20psi at the track.
Old Feb 17, 2002 | 03:01 PM
rockyoysterTA's Avatar
What would be the benefits of having air bags, aside from the ability to vary the PSI.
Old Feb 17, 2002 | 04:40 PM
[quote]Originally posted by rockyoysterTA:
<strong>What would be the benefits of having air bags, aside from the ability to vary the PSI.</strong><hr></blockquote>
An airbag in the right rear spring will keep the car from squatting on that side, allowing for a level launch. With a perfect drag setup, you don't want any squat in the rear. A level launch will keep the car straight off of the line.
__________________
Old Feb 17, 2002 | 10:12 PM
why would it squat only on the right and not on the left as well??
Old Feb 17, 2002 | 10:14 PM
Old Feb 18, 2002 | 12:51 AM
WEASEL's Avatar
ToRqUe AnD lOtS oF iT.
Old Feb 18, 2002 | 08:46 AM
exactly right Have you ever watched an engine under the hood when you rev it hard? When you rev it you can see it torque over towards the pass. side. Well, the same thing happens w/ power running through the drivetrain. Have you ever seen a car at the dragstrip just BARELY pull a wheel on the launch? Chances are it was the driver's-side wheel. I used to race with a guy that had a small-block in a '68 Chevelle, and he would pre-load the suspension for the launch. The car had a rake and would sit lower on the front driver's-side than it would on the front pass. side. It was crazy to look at since the highest point was the rear pass. side. When it launched it was straight as an arrow and completely level. <img src="gr_stretch.gif" border="0">
__________________
Old Feb 18, 2002 | 10:25 AM
SteveD's Avatar
Very well explained Trevor. <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
