??? driveshaft / vibration ???
The yoke is inside the trans about 2-3/8". It only moves about 1/16" at most.
Car is equipped with fully adjustable spohn frame mounted torque arm.
Trans angle is -4 the pinion angle is +2. I already tried the pinion angle adjustment by going from the ground to the rear, and from the driveshaft to the rear. So far my vibration is SLIGHTLY better with this final adjustment.
I'm not sure if the travle on the yoke is normal or not. If I raise the entire car instead of just the rear would that make a differnece?
