is it times for gears
Old Oct 27, 2005 | 12:27 PM
MARKSZ71's Avatar
Default is it times for gears
well i think im gone as fast as i can on stock 323s on my head and cam car,i have prc heads and a custom cam in the 230 range,im trapping 95mph in the eighth and shifting around 6400,any ideas
Old Oct 27, 2005 | 12:44 PM
monicaz28's Avatar
Is your car an A4 or M6? And if it's an A4, what kind of stall do you have?
Old Oct 27, 2005 | 01:25 PM
TA TECH's Avatar
Ya better get a bigger rear if ya r ,don't waste$ on the 10 bolt! 3:73s r nice!Get a nice 12 bolt!
Old Oct 27, 2005 | 02:31 PM
MARKSZ71's Avatar
i cant afford a 12 bolt right now,i have a 3800 stall from tci
Old Oct 27, 2005 | 02:58 PM
12secSS's Avatar
What size tires are you using. If you are shifting at 6400 and going through the traps in 3rd, then you are pretty well setup. 3.73s will put you higher in the rpm range and you may run the risk of shifting into 4th. Which is not a good idea.
Old Oct 27, 2005 | 04:06 PM
monicaz28's Avatar
3.73's would be alright if you run the 1/4...
But then I don't know all the variables of your car.
I, myself, am putting 4.10's in mine. I don't run the 1/4 anyways, it will just be an 1/8 mile car pretty much.
I guess it all depends on what you're trying to do with it.
Old Oct 27, 2005 | 09:00 PM
TA TECH's Avatar
Mark read this post real good should tell you that the 3:23s are fine with your stall size!
https://ls1tech.com/forums/gears-axles/376207-want-know-effect-changing-gear-ratios-look-here-first.html
