SUBFRAME CONN. QUESTION!!!
Old Feb 20, 2002 | 09:48 AM
Lance's Avatar
Default SUBFRAME CONN. QUESTION!!!
Hello everyone! If I lower my 2001-SS w/eib.Pro
springs,(should lower the car about 1.5" all
around), along w/SLP shocks, will I have clearence problems if I bolt on SLP's SFC??
Lance <img src="gr_images/icons/cool.gif" border="0">
Old Feb 20, 2002 | 10:56 AM
TheBat's Avatar
Default Re: SUBFRAME CONN. QUESTION!!!
No. The first thing to hit the ground whether you lower your car or not will be your exhaust, even with SLP SFC's. The SFC don't cause any ground clearance probs.
-bat
Old Feb 20, 2002 | 07:08 PM
FaSS Blac's Avatar
Get the Global West 2" tubular SFC for '93-Up cars. You can't even see them when their welded in unless you lay down under the car. How's that for G.C. <img src="gr_grin.gif" border="0"> Bolt ons will just end up oblonging the mount holes and get loose any way. This is a permanent mod EVERY F-Body owner needs to make anyway!!
Old Feb 20, 2002 | 07:45 PM
Lance's Avatar
That sounds better...I'll look into that!
Thanks #1682!!!
Old Feb 21, 2002 | 12:22 AM
Lance's Avatar
Thanks!!
Lance <img src="gr_stretch.gif" border="0">
