Re: How important are Subframe connectors?
You guys aren't going to believe this, (just posted on which front rotors to get) but I just had some Global West SFC welded in on Monday (Yeah, I just did the rotors on Sunday). Mufflex in Trenton welded them up in about an hour and a half. They do reall good welding. They took their time and weld SFC at every possible attachment point. Car handles like...... night and day!!! You feel a little more bumps on the road but just make car feel more "taunt". When you go fast into a turn, then you really feel the bennies of having SFCs!! Car justs zips into the turn and just zooms out!!!! You can yank the car into a turn your brain tells you is going to put you up over the curb and the car will still lean, but it is all on the suspension, not frame and suspension. going into steep drive ways, car doesn't "snake" anymore!!! That annoying "where's it coming from" squeeking I had in the left rear T-top corner on real bumpy roads has misteriously disappeared!!! I would say SFCs are VERY important on not only T-top cars, but also hard tops. My '95 M6 Z28 had about 98,000 miles on it when I had the heads/intake ported. We decided to change the clutch/press plate just as a precaution. While the trans was down, I did a depot level inspection (former aircraft inspector, 7 Level). I noticed a approximately 3"-4" crack in the trans tunnel!!!! This car was only turning 13.3's @ 106 mph, 2.0-1.9ish '60's!!! This was bumped up to 12.50 @ 111 mph, 1.85 '60 best. This was a hard top car!!!! It began to feel very loose as the miles rolled on. The morale to this story is GO OUT AND BY SOME GOOD WELD IN SFC's!!!!!!!!!!!!!!!!!!!!!! BTW, my MASSIVE 2" dia tube Global West SFC's feel to be about 20 lbs for THE PAIR!!!! One of my new front rotors is heavier by far than BOTH of my SFC's!!!!!! I work at a warehouse now all day picking up stuff, so I KNOW WEIGHTS!!!!! Go get some!!! <img src="gr_grin.gif" border="0"> P.S. The guy's at Mufflex are a Friendly lot. Denny has a very interesting story about his 2001 SS convertible from HELL!!!!! If you get work done there, ask him about It!!!!!!!!
[ February 20, 2002: Message edited by: FaSS Blac ]</p>
