UMI relocation brackets?
Old Nov 3, 2005 | 03:02 AM
bigdsz's Avatar
Default UMI relocation brackets?
I have these brackets and will probably be installing them next week. They drop the lower control arm further down for improved geometry, so there should be less wheelhop with my MT DR's. Anybody put them in and what were the results? They appear to be a well built product.
Old Nov 3, 2005 | 08:09 AM
CATCH ME's Avatar
make sure u get them welded in...mine were just bolted up and one of them twisted creating a lot of suspension problems. aside from that they seem like a good solid piece.
Old Nov 3, 2005 | 08:15 AM
2001 Pewter WS6's Avatar
Restricted User
I went from 1.62 60' times with severe wheel hop to 1.49 60' times and pulling the wheels 12" in the air.
Old Nov 3, 2005 | 08:20 AM
bigdsz's Avatar
Did you install the brackets to specifically limit wheel hop? Did it work? Did you use the lower or middle bolt holes on the bracket? Thanks for your help.
Old Nov 3, 2005 | 08:31 AM
kyles2000z's Avatar
always use the lowest holes regardless of your ride hieght. the lower those control arms are in the rear, the better. i dropped my 60 ft a little over .1.
Old Nov 3, 2005 | 09:23 AM
Restricted User
I used the bottom hole. I got them specifically to eliminate wheel hop. My car is lowered 1" as well. Wheel hop wiped put the ring gear in my rear and broke the foward sprag in my tranny.
