Can someone help me, what kind of yoke is this??? (pic inside)
Old 11-17-2005, 01:11 AM
regorih383's Avatar
Question Can someone help me, what kind of yoke is this??? (pic inside)
I can't find out what kind of yoke this is. In the picture I have put the yoke on the u-joint of a stock LS1 DS so that you can see that its way bigger than a stock yoke.
So what kind of yoke do you think its for?
Thanks,
Roger
Old 11-17-2005, 07:25 AM
TRex's Avatar
Count the spline grooves, then ask us.
Old 11-17-2005, 12:42 PM
regorih383's Avatar
thanks
Old 11-22-2005, 05:15 PM
regorih383's Avatar
it has 30 grooves
Old 11-22-2005, 10:39 PM
TRex's Avatar
30 splines could be one of three types:
1. Ford 8.8
2. GM 8.5 10 bolt
3. GM 8.75 12 bolt
Doesn't look like a ford, because they usually use a pinion flange, and given the ujoint size I would guess it is a 12 bolt bolt GM
Where did you get it ?
Old 12-14-2005, 02:38 PM
regorih383's Avatar
Well im going to say its not a 10bolt yoke because it wont fit my aluminum DS.. When i bought the DS for some guy hey gave it to me as a package deal. Do you think this yoke is worth any money????
Thanks Roger
Old 12-14-2005, 02:56 PM
TRex's Avatar
Only if you can figure out what it is and find someone that needs it ???
Old 12-14-2005, 04:24 PM
peterock98's Avatar
Thanks Roger
What u joint do you have on your DS stock or 1350?
Old 12-14-2005, 11:11 PM
86irocz's Avatar
Thats a transfer case flange. 30 spline would fit a 12 bolt but that pinion flange looks to be too narrow for a rear axle.
Old 01-06-2006, 01:16 PM
FIREHAWK #07's Avatar
count again whorebag.. . .probably 31 splines....
Old 01-07-2006, 06:23 PM
regorih383's Avatar
no its 30
