Detroit True Trac in a 12-Bolt?
Old 12-06-2005, 03:25 PM
  #41
pushinfreight's Avatar
If someone else has ordered the true trac in the strange product alot of us would like to know where they obtained it from. Strange told me that right now it just does not fit well and could not recomend the unit in their product.
Old 12-06-2005, 03:35 PM
  #42
Predator's Avatar
I was thinking the same thing.
Old 12-07-2005, 06:46 AM
  #43
John35thSS's Avatar
The abs reluctor ring did not line up properly with the senser, in the strange rear they use a aluminum o ringed plug with a bolt to set orientation. I had to grind another groove for that allen head bolt and make sure I had enough voltage at the output of the senser (spun diff).
As to fitting in the case it is a bigger unit and has a different sized splined ring for abs that moser fabricates. But it does fit even though the strange is smaller internally.
John
Old 12-16-2005, 05:28 AM
  #44
Awake455's Avatar
Originally Posted by Hawkcmc
......... Strange also has attachment points on their housings for brake lines and cables while Moser does not. .......
CMC
Hmmmmm......
How about a GM solution to mounting the brake lines? GM just calls it a strap on the 'puter, part number 15193721. Used on the newer trucks & SUVs. Adjustable to fit various size axle tubes. Relatively inexpensive, under 5 bucks each. I will try to get a pic of one today & splat it up here somewhere.
Old 08-12-2017, 06:46 AM
  #45
Xander's Avatar
Default Tru trac in a 12 bolt 30 spline 4speed gearbox
Hi I'm putting an eaton tru trac in my 12 bolt 30 spline and have a 4 speed m22 has anyone had any problems
Quick Reply: Detroit True Trac in a 12-Bolt?
