Pinion Problem Please Help
Old Nov 28, 2005 | 08:43 PM
XpEdItIoUs's Avatar
Default Pinion Problem Please Help
Ok here it is, I installed the bmr adjustable torque arm and the transmission crossmember with the relocation bracket. Now everytime i go wot in 1st gear i get a vibration at high rpm's and when i leave it in neutral going 80+. I set my pinion angle at -2 and the end of the torque arm is on the second holes from the top on the bracket.
Old Nov 28, 2005 | 10:54 PM
Steve Burger's Avatar
LS1TECH Sponsor
Try setting the pinion at 0 and see if the problem goes away. Check U Joints too.
Old Nov 29, 2005 | 05:27 PM
XpEdItIoUs's Avatar
I also think its my poly trans mount, it makes my trans sit's higher and changes the angle of my trans tailshaft.
Old Nov 29, 2005 | 08:18 PM
XpEdItIoUs's Avatar
Problem solved thank's Steve Burger for the help i guess your the only one here who can take some time to help.
