View Poll Results: aftermarket gear ratios
3.73
118
29.21%
4.10
237
58.66%
4.30
30
7.43%
4.56
19
4.70%
Voters: 404. You may not vote on this poll
What gears you M6 guys runnin?
i was pullin consistent 12.30s and 12.40s with a lid, catback, and nittos with a full wieght car and stock suspension, stock clutch and stock 10 bolt[/QUOTE]
Good Driver..good track. Good Times
I used 4.10s for 3 years and had fun with them but also had terrible luck with either bad installs or breaking teeth off of them. I went 3.73s to try and avoid that and so far so good. The acceleration is still great as well.
i must say i can drive mycar pretty well but the track was a lowrent track with hardly any prep but i always got my best times there
i was gettin 12.40s with 1.95 60fts and i did get a 12.38 with a 1.85
and my best mph was 115 backed up by a few 114s
i was like damn myself
I want gears, but I don't want to run out and have to shift to 5th at the track when I spray on top of my planned heads/cam setup. So I guess I will run the 3.42s until I swap in a rear. Then I am thinking 3.90s??? Whatever will work well with 26" tires and not run out of gear in 4th. Time will tell.
#36
I got the rear end and gears on my car now. I just need to buy a nitrous system and get it hooked up now.
