Difference between tp4400 and 4600
Old Mar 2, 2002 | 03:24 PM
AlonzoVersion 1.0's Avatar
Default Difference between tp4400 and 4600
I ordered mine with a 4600 stall.What are the differences between the two.Should I get mine restalled to a 4000.I figured it was better to get the bigger stall for better times.But I dont go to the track often I street race a lot.Should I have gotten the lower stall for less torque multiplaction.Also does the higher stall make the converter less efficent up top?Thanx
Old Mar 2, 2002 | 09:11 PM
Ragtop 99's Avatar
Default Re: Difference between tp4400 and 4600
4600 is a crap load of stall for basically a street car and on the edge of much stall for a stock motor.
Do you street race (with ET streets, 1/4 mile marked, money on the line, etc.) or stoplight race (nittos aired to at least 24 lbs and basically run anything that revs on you)? A YTP 4400 is fine for street racing. For stoplight racing a SY 4000 or YTP 4000 would make more sense.
Old Mar 3, 2002 | 03:15 AM
[quote]Originally posted by Ragtop 99:
<strong>4600 is a crap load of stall for basically a street car and on the edge of much stall for a stock motor.
Do you street race (with ET streets, 1/4 mile marked, money on the line, etc.) or stoplight race (nittos aired to at least 24 lbs and basically run anything that revs on you)? A YTP 4400 is fine for street racing. For stoplight racing a SY 4000 or YTP 4000 would make more sense.</strong><hr></blockquote>I street race alot not to much into the stop light racing as it just draws unwanted attention.I do my dirt when its a bit more organized.My motor is not stock though I do have heads and cam and headers etc..I run on bfg drag radials (315).
Old Mar 3, 2002 | 03:17 PM
Ragtop 99's Avatar
Not sure that BFGs will hold the 4600 converter, even the 315s. I'd probably go with a YTP 4200 to gain a bit more top end efficency since I don't think you can use 100% of a YTP 4600's bottom end capability (unless you have 2.73 gears).
Good luck in your choice.
Old Mar 4, 2002 | 03:46 PM
WILWAXU's Avatar
You will need to learn how to pedal it with DR and a TP-4600. I suggest you look into a set of ET Streets. The TP's are AWESOME from a roll.
I have a UT-4600 (more STR), I run 315 DR (Nitto) as my streets tire, but I do not do any "street racing" other than the chance meetings <img src="gr_images/icons/wink.gif" border="0"> . The Nitto's do a great job at holding the car.. but most of that is knowing how much power I can apply.
Old Mar 4, 2002 | 04:41 PM
So what your saying is that if I lower my stall to 4000 it will be more effiecent up top.I know it will be impossible to use the bottom end on the street because I also have 3.73s out back.But I like top end better than the bottom end on the street because you cant use bottom end on the street unless you have some et drags or streets on.
Old Mar 4, 2002 | 04:44 PM
[quote]Originally posted by WILWAXU:
<strong>You will need to learn how to pedal it with DR and a TP-4600. I suggest you look into a set of ET Streets. The TP's are AWESOME from a roll.
I have a UT-4600 (more STR), I run 315 DR (Nitto) as my streets tire, but I do not do any "street racing" other than the chance meetings <img src="gr_images/icons/wink.gif" border="0"> . The Nitto's do a great job at holding the car.. but most of that is knowing how much power I can apply.</strong><hr></blockquote>I hear you on the pedal part.Just out of curiosity how does it feel to drive your car around.I made a huge jump going from a vig 2500 to a yank 4600 and I just want to know if its something you get use to in a day or so.Even if you dont oh well whatever it takes to stay with the pack.
