Whining gears: bad install or defective gears?
I have a Currie 9-inch rearend with 4.11 gears that have always whined pretty loudly. Is there any way to tell if they're whining because they weren't setup right or if they're whining because the gears themselves are bad? The reason I ask is because I'm about to drop the center section to change the posi, and am debating replacing the ring and pinion to see if it will reduce the whine. Thanks.
