Need Napa u joint part #...
Old 12-26-2005, 06:36 PM
REDSS01's Avatar
Default Need Napa u joint part #...
The Moser 12 bolt came in and I need to swap this thing ASAP, but I need a 1350 to 1310 u joint. I have searched many times about it and most people said Napa part #477. Went to Napa and asked for it and the guy came back with this huge u joint(like 10" diameter), he kept showing others u joints but since I have no clue which one was, I didn't buy it. I did find one on their website that might be the one I need.
http://www.napaonline.com/MasterPage...on+-+Universal
Item#: PUJ348
Price: $28.99
tax and shipping not included
Attributes:
Ujoints Combined:331 x 369
Bearing Dimensions: Diameters 1.063 " & 1.188 "
Bearing Type:Round Plain
Contents:1 U-Joint
4 Lock Rings
1 Grease Fitting
Driveline Series Combined:Spicer 1350 x Spicer 1310
Features & Benefits:Combines two different driveline series.
Fitment Dimension:3.62 " & 3.22 " Over Bearing Cups
Grease Fitting Location:Between Trunions
Old 12-26-2005, 08:55 PM
VSGLS1's Avatar
Think he might have had the wrong part beacause it is a 447 with the 1350 and stock DS.
Old 12-27-2005, 12:14 AM
Gary Z's Avatar
The stock u-joint is a Saginaw 3R, not a Spicer 1310. Napa part number 240-0447 is a 3R to 1350 conversion u-joint.
Old 12-27-2005, 04:58 AM
REDSS01's Avatar
If you go to their website and type 240-0447 it says no matches found.
Old 12-27-2005, 06:59 AM
EPP
EPP's Avatar
Hmm, most Napa stores can produce the right U Joint if you tell them you need a 447 U Joint for the 1310 to 1350 conversion. Bob
