Putting in 10bolt rear
Old Dec 28, 2005 | 02:07 PM
sp00rkz's Avatar
Default Putting in 10bolt rear
I'm putting in a new 10bolt this weekend. It's a built 4channel WS6 take off. It is comming with everything but the swaybar and rotors ( brake stuff ). I currently have a 3channel rear end. God knows why I do but here are pictures. If you want higher res go up a folder.
http://www.f7lans.com/mike/Camaro/Re...0swap/Cropped/
My question is what do I need to do to make my new 4channel ABS stuff hook up to my 3channel ABS stuff. Please feel free to use/edit my pictures for reference purposes. I do not care if TCS doesn't work anymore, but I would love ABS. I know how to do everything else except hooking this crap up.
Also, are there Torque specs for the bolts/nuts on the 10bolt axle?
Reference with this stupid TCS/ASR/3channel crap
https://ls1tech.com/forums/gears-axles/426731-asr-tcs-abs-question.html
And please, correct me on ANYTHING if I am wrong
Old Jan 3, 2006 | 12:35 PM
mondi2002's Avatar
Weird, looks like you have a 3 channel rear from the pic of the center section.
But i am pretty sure the 4 channel sensors would be on the Brake backing plates.
Did you get the replacement rear yet? you can look at that.
If you have 3-channel the 4-channel will work but there is no way to hook up the ABS.
I am going to swap mine soon, probably going with the 9 inch & ditching ABS.
Good Luck. Keep me updated.
