question bout u-joint and 12 bolt????
Old Jan 18, 2006 | 07:48 PM
mcamarols1's Avatar
Default question bout u-joint and 12 bolt????
i bought my moser 12bolt from speed inc. and it came with a 1350 u-joint so i can use my stock DS, well this happened to the u-joint
https://ls1tech.com/forums/gears-axles/434609-i-need-help.html
can i just go get one from autozone or this u-joint diff. and i have to get it from speed inc.???
Old Jan 18, 2006 | 08:06 PM
01'WS6's Avatar
Go to your local auto part store. The napa and precision number is a 447.
Old Jan 18, 2006 | 09:29 PM
mcamarols1's Avatar
so theres nothing special about the conversion u-joint it came with????
Old Jan 18, 2006 | 09:30 PM
mcamarols1's Avatar
does the stock DS have locks to keep the u-joint in place??? what do you guys recomend i dont have the money for a new DS for now just need the car to do some runs on it.
Old Jan 19, 2006 | 08:34 AM
J&J Speed Shop's Avatar
Sometimes you need an aftermarket driveshaft because there simply isn't enough clearance. Make sure you have enough room so the driveshaft isn't bottoming out in the tranny
Old Jan 19, 2006 | 12:39 PM
01'WS6's Avatar
Nothing special about the u-joint its just a conversion joint because the yoke on your 12 bolt uses bigger cups than the driveshaft.
