Why such steep gears??
This all works out perfect if you wind up in high gear at the end of the quarter mile while your engine is at maximum horsepower on the RPM curve. Manual shifters will find they are shifting much sooner through each gear with the higher ratio.
Besides, if you find you don't like them you can always start out in second.
It's not a stupid question. For a street car, deeper gearing doesn't necessarily improve things.
Now for racing purposes, the right answer was given. You want to run through the finish line at max hp.
When I added 4.10s I found that my car was EASIER to launch on street tires. Before it would bog down really bad but now it is very easy and consistent to 60' low 1.9X's all day. Can't wait to try some drag radials.
