Roaring from rear
Old Jan 25, 2006 | 11:38 PM
ryansm1's Avatar
Default Roaring from rear
My car has 101k miles on it (98 model) and makes a dull roaring kind of sound that is simultaneous with the rotation of the rear wheels. It's not the wheels being out of balanced or the tires (new tires and had them balanced, neither fixed the problem).
Could the axle bearings be the culprit? Would there be anything else that would cause the noise? I'd rather just fix it than try to drown it out by using a little more throttle.
Old Jan 26, 2006 | 12:57 AM
86irocz's Avatar
Carrier bearings are usually the problem, but with that many miles I would opt. for a whole rebearing job.
Old Jan 26, 2006 | 03:47 PM
Carter Hays's Avatar
Yes, bearings
Replace all six bearings plus races. Mine were pitted at 58k
Old Jan 26, 2006 | 07:01 PM
1badA3Z's Avatar
sounds like a typical 10 bolt for ya, ha ha ,but hope u find ur prob tho,goodluck
Old Jan 26, 2006 | 07:14 PM
ATCFLYBOY02's Avatar
Cant u just get the bearing from NAPA?? or something like that?
Old Jan 27, 2006 | 06:28 PM
ryansm1's Avatar
I know you can buy several of the bearings from local auto places, but I think I am just going to buy a kit from Thunder Racing and replace all the bearings.
Thanks for the help
Old Jan 28, 2006 | 11:05 AM
KurtRardin's Avatar
Veteran: Marine Corps
My rear is roaring too. It seemed to happen when i first moved my car after i changed over to ZR1 wheels. It was quiet before wheels, then wheels and noise....so i put the stockers back on and it still made noise. Strange coincidince? So, im just enduring it now. Here in a bit im going to get a 9" and forget about the whole damn rear end all together for the life of the car. Im tired dogleg turns under acceleration, and constantly worrying about the rear pipe-bombing.
Old Jan 28, 2006 | 11:07 AM
KurtRardin's Avatar
What the heck did i do? Did muck the brakes up? I went to 100 lb/ft torque on the lugs. Too much? I also get a nice whoop whoop whoop noise at about 35 from the front. Im half way wondering if its just 10bolt noise going up the drivetrain. it only makes the noise in the front at 35ish. At 80mph its smooth, with only rear noise. Pain in the butt.
