View Poll Results: which rear gear oil is best?
redline
12
21.43%
royal purple
36
64.29%
lucas oils
4
7.14%
dinosaur(coventional) oil
5
8.93%
Multiple Choice Poll. Voters: 56. You may not vote on this poll
favorite synthetic gear oil
Originally Posted by black00TA
ive had best results from Mobil 1 75w90
and of course the tube of posi additive.
GM calls for these cars to have rear-end fluid changed every 7,500 FYI
7,500 or 75,000?
#32
ive also heard mixed reviews, i wont take the chance.
i know the torsen dif calls for posi additive. im pretty sure the SS has the auburn if im correct, i dont own an auburn so i couldnt tell ya FOR SURE on that one.
#35
You didnt specify on use.
Engine = Mobile1 or RedLine
Transmission (M6) = Redline ATF with 1qt of MTL
Differential = Torco, Almasol or Amsoil. (~Straight 140wt only~)
Powersteering = Redline (~only~)
#36
Differential = Torco, Almasol or Amasoil. (~Straight 140wt only~)
#38
Originally Posted by dailydriver
If you had a diff that forbade the use of synthetics, would you use the Torco RGO, Lucas petroleum, or the Lakewood BFL?? Have you actually used the D4/MTL combo in your T56, and if so what year and for how long??
Second question. Yes. I dont actually understand the relevance to what year the vehicle and/or tranmission is. A T-56 is a T-56...... is a T-56. My chassis is actually a 1967. I did however, start using that formulation somewhere back in 92-93 (uhm, yeah.... 1992) when we were running the very same transmission in the Challenge Series classes. The T-56 was later released in the production 93 platform.
The MTL is merely added to aid in shifting, as it takes away some of the 'notchiness' in performance built T-56 transmissions.
Spuds~ I would use a straight 140wt, non-synthetic.
