Need help with this pattern - pics inside
Old Feb 4, 2006 | 07:06 PM
  #41
DynoDR's Avatar
Originally Posted by sscam68
Thanks a lot for your guys help.
I got the new pinion bearings today and pinion shims. I'll be tearing into it tommorow.
Edit: Question, why are you emphasising (sp?) the coast side vs the drive side?
When I was setting up the gears I got the coast side perfectly, at least it looked like to me. The pattern was centered on the gear and had a nice symmetrical oval shape, BUT the drive side looked biased towards the inner portion of the ring. I didn't quite know how to interpret it so I decided to center the drive side and the the coast fall where it may. Input?
If the gears have many miles on them it is sometimes hard to get a accurate pattern from (I should say JUST from) the coast side. As for you saying the way yours looked, if it was that clean on the drive side and the coast was biased a little, I would try moving the backlash only a couple thousands and see if it helps the coast. BUT, if the coast got better and the drive side went to hell, move it back to were it was. What I mean is sometimes a couple thousands change in lash will help one side alot without really effecting the other.
And with some gear sets no matter what you go you are not going to get a nice center oval pattern. The newer 2 cut gears are a little different also.
The point is to get it as ideal as you can with the set you are working with. If it is going in a SUV, Van or station wagon I get real picky with the brand of gear and the final pattern. That passenger compartment over the axle is a damn amplifier.
Old Feb 4, 2006 | 07:30 PM
  #42
DynoDR's Avatar
Originally Posted by Firebird!
Okay - I'll go shop tomorrow for the new crush sleeve (hopefully my parts stores will have one - hate to order it online)
Should I get the new pinion nut too, or the one I'm using will be okay?
If they have one get a new pinion nut although I would not loose any sleep over using the one you have. Put a little red loctite on it and stake it after you get your preload set and it will be just fine.
Again for a few dollers get another nut if they have one in stock.
Old Feb 5, 2006 | 06:54 AM
  #43
DaddySS's Avatar
Excellent job by the way! The coast side is more important on used gears as stated before. Don't worry so much about the heel and toe position of your pattern versus the flank and face (inner and outer edge of the gear). It is very difficult and sometimes near to impossible to get a perfect battern. You want the pattern nicely centered on the gear and if it's a little biased to the heel or toe that's OK. With 3.42s your current position should be just fine. Make sure your carrier preload is good and solid, err on the side of too tight if anything so the total preload should be (for new bearings) 32 - 55.
I like your tenacity in trying to do it right - good job!
Old Feb 5, 2006 | 10:28 AM
  #44
Firebird!'s Avatar
Just like always - no one has an idea what is a crush sleeve
Ordered solid spacer from ratech
Shut - maybe I'll finish by the next weekend
BTW is there any way to mesure carrier preload?
Thanks guys
Old Feb 5, 2006 | 11:16 AM
  #45
SScam68's Avatar
Thanks guys
Actually thats what I was asking DynoDR about when he threw out the .01-.012 figure. You basically get the carrier in nice and snug, not necessarily tight. Then add shims on both sides that equal about .01-.012.
For example, I get the carrier in snug and get two .0065 shims and add one on each side. Its a real PITA to get them in but the "lock" clutch pack has some real thick flanges so messing up the shims themselves isn't an issue. I even bought a tool for it to spread the load over the entire shim pack when I hammer it in with a dead blow hammer.
Old Feb 5, 2006 | 11:24 AM
  #46
DynoDR's Avatar
Thanks guys
Set your pinion to about 20 in lbs and after installing carrier you should be in the 30-40 range for the total preload. The carrier bearing preload is alot more forgiving than the pinion though.
I like to zero endplay plus .008 or so.
Old Feb 5, 2006 | 11:29 AM
  #47
DynoDR's Avatar
Scam
What post are you refering to? Are you sure I was not refering to a backlash setting?
As far as adding .010-.012, I really don't like them that tight. No more than about .008 usually is fine.
Old Feb 5, 2006 | 11:51 AM
  #48
DynoDR's Avatar
Originally Posted by DynoDR
sscam,
Although you really do not need anything less than a .010-.012 on the carrier to get it where you want as long as you have a good selection. .011,.013,.015-and up.
Also the only thing you have to watch for on some of the selectable interlocking shim packs is sometimes the thickness varies alot
Later
Scam
Is this the .010-.012 figure you are talking about? If so I was talking about the shim thicknesses that are available in the kit not the total preload or what to add to the shim pack.
Old Feb 5, 2006 | 03:37 PM
  #49
SScam68's Avatar
Yep. sorry, misread.
Old Feb 5, 2006 | 04:28 PM
  #50
Firebird!'s Avatar
Hey guys me again with pictures
this is drive and coast sides with 007 backlash
Attached Thumbnails Need help with this pattern - pics inside-d022pd_007bl.jpg   Need help with this pattern - pics inside-c022pd_007bl.jpg
  #51
Firebird!'s Avatar
and this is with 010 backlash
what do you think?
Attached Thumbnails Need help with this pattern - pics inside-d022pd_010bl.jpg   Need help with this pattern - pics inside-c022pd_010bl.jpg
Old Feb 5, 2006 | 06:19 PM
  #52
DynoDR's Avatar
what do you think?
Looks better. Are these used gears?
Old Feb 5, 2006 | 08:35 PM
  #53
Firebird!'s Avatar
Yes - Seller said it is 8000 miles on them
Old Feb 5, 2006 | 08:49 PM
  #54
DynoDR's Avatar
OK. Check them at .012 or .014 and lets take a look.
Old Feb 6, 2006 | 04:41 PM
  #55
Firebird!'s Avatar
Here it is 0.0125 Backlash
Attached Thumbnails Need help with this pattern - pics inside-d022pd_0125bl.jpg   Need help with this pattern - pics inside-c022pd_0125bl.jpg
Old Feb 6, 2006 | 04:42 PM
  #56
Firebird!'s Avatar
And 0.015 Backlash
Attached Thumbnails Need help with this pattern - pics inside-d022pd_015bl.jpg   Need help with this pattern - pics inside-c022pd_015bl.jpg
Old Feb 6, 2006 | 08:24 PM
  #57
DynoDR's Avatar
That looks pretty good to me. See if you can put a little more resistance on the pinion while turning the ring gear. The coast is a little iffy but mostly because it looks like it did not have much drag on it when you were turning the gear, not from the setting.
And try not to use as much gear compound, brush on only enough to cover the teeth.
Old Feb 6, 2006 | 09:30 PM
  #58
Firebird!'s Avatar
Okay - I'll try to do that in the morning.
Is that would be okay if my drive side pattern is centered on the gear, even a bet on a left side?
Old Feb 6, 2006 | 11:06 PM
  #59
BudH's Avatar
I would go with the pattern at .010 !
Old Feb 7, 2006 | 09:14 AM
  #60
Firebird!'s Avatar
Here is again 0.125 backlash with me holding pinion with one hand
Attached Thumbnails Need help with this pattern - pics inside-d022pd_0125bl2.jpg   Need help with this pattern - pics inside-c022pd_0125bl2.jpg
