are the 10bolts interchangable from 93-02
Old Mar 14, 2002 | 09:35 PM
JPJBC's Avatar
Default are the 10bolts interchangable from 93-02
well tia
Old Mar 15, 2002 | 01:30 AM
Reckless's Avatar
Super Moderator
Default Re: are the 10bolts interchangable from 93-02
yep
Old Mar 15, 2002 | 08:58 AM
Camaroholic's Avatar
If you're pulling a rear from an LT1 car and want to use the LS1 brakes, you'll need to remove the LS1 backing plates and bolt them on to the LT1 rear end. The backing plates are different, but the rest of the rear looks to be the same.
(got one of each sitting on my garage floor)
-Andrew
Old Mar 15, 2002 | 10:19 AM
onfire's Avatar
Coal Mining Director
I made a Strange 12bolt for a lt1 fit an ls1 by changing the brake backing plates....also, make sure it is setup for your antilock brakes...3channel uses a plug on top of the diff...4channel has a sensor at each wheel and is used with traction control.
Old Mar 15, 2002 | 04:32 PM
nbm99ta's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Camaroholic:
<strong>If you're pulling a rear from an LT1 car and want to use the LS1 brakes, you'll need to remove the LS1 backing plates and bolt them on to the LT1 rear end. The backing plates are different, but the rest of the rear looks to be the same.
-Andrew</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">In addition, the LS1 axles are 1/4" longer, so it may be a good idea to swap those too...
There may be some clearance issues...
Old Mar 16, 2002 | 02:36 AM
Damian's Avatar
LSX Mechanic
Well it really depends.....
You can put an ABS LS1 rear in an ABS LT1 car, but you cannot mix them up. LT1's have two ABS/TCS sensors mounted on the end of each axle bolted to the backing plate, reason being the sensor rings are on the end of each axle as well. As to where the LS1 sensor ring is located in the differential so the sensor plugs in on top of the differential.
I have installed an LS1 rear on my buddy's LT1 by swapping the axles, and bolting on the sensors. Everything worked, but if you tried to mix up the combo w/ a non TCS car and a TCS car things could get complicated or not even worth the trouble
Josh
Old Mar 19, 2002 | 02:23 PM
nbm99ta's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Damian:
<strong>You can put an ABS LS1 rear in an ABS LT1 car, but you cannot mix them up. LT1's have two ABS/TCS sensors mounted on the end of each axle bolted to the backing plate, reason being the sensor rings are on the end of each axle as well. As to where the LS1 sensor ring is located in the differential so the sensor plugs in on top of the differential.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Any 93-02 f-body with traction control has these reluctor rings on the ends of the axles, whether its an LS1 or LT1. Also, the Wheel Speed Sensors are mounted to the backing plates. The WSS's are used for ABS and traction control in this case.
The sensor in the middle of the pumpkin is an ABS sensor, which is only used on cars without traction control.
