TRUE DUALS - Spohn Bolt-In Driveshaft Loop?
I'd like to run a dual-loop setup on my driveshaft, but as far as I can tell, that isn't possible with the true duals. En Lieu, I've found this driveshaft loop from Spohn:
Lakewood also produces a similar looking loop for our cars, although I'm not positive that it is adjustable like this Spohn unit.
Is anybody using this loop with true duals?
Anyway, I have a Lakewood, my x-pipe falls right where the loop is which kills ground clearance. They also rub so I wraped each of them with header wrap to keep them quiet. The Lakewood does have the best clearance of all the loops I have seen.
Also, I'm not into show, I'm into passing the safety inspection at the track...(and good ground clearance) whatever works is what I'm looking for. If anyone can come up with a pic (Lakewood or Spohn or whatever) it would help, I would know right away if it'll work or not, and save me the hassle of ordering one and returning it...
I'd show you a pic of mine, but I removed my exhaust to pull my trans and I'm still waiting on my torque converter...
https://ls1tech.com/forums/lt1-lt4-modifications/639256-pix-new-3-stainless-true-duals.html
--Alan
https://ls1tech.com/forums/showthread.php?t=639256
--Alan
Thanks Alan...
