Are Moser 12 Bolts junk?
Old Mar 20, 2002 | 11:08 AM
Phil99TA's Avatar
Default Are Moser 12 Bolts junk?
When the Moser 12 bolt hit the scene, we all seemed to see it as a blessing, but in many cases it has been nothing but a headache for alot of people. Broken posi's, gear whine/breakage, and leaks are some of the biggest problems. Whats your opinion of it?
<small>[ March 20, 2002, 11:10 AM: Message edited by: Phil99TAsoon ]</small>
Old Mar 20, 2002 | 11:09 AM
highgmc's Avatar
Default Re: Are Moser 12 Bolts junk?
I hope it's not junk, mine should be here any day...
Old Mar 20, 2002 | 11:46 AM
Dean98TA's Avatar
If you knew that the components inside a Moser rear-end are the same components found inside Strange and KTRE, would you still blame Moser for broken posi's, gear whine etc?
The only thing that is "Moser" in a Moser 12-bolt, is the housing. Everything else is the same components found in any other 12-bolt housing.
Old Mar 20, 2002 | 02:20 PM
Phil99TA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dean98TA:
<strong>If you knew that the components inside a Moser rear-end are the same components found inside Strange and KTRE, would you still blame Moser for broken posi's, gear whine etc?
The only thing that is "Moser" in a Moser 12-bolt, is the housing. Everything else is the same components found in any other 12-bolt housing.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Are you sure about that? I'm pretty sure Strange 12 bolts use Strange axles (although axles seem to be the only bulletproof part in the Moser so far) and Auburn posi's instead of the Eaton
Old Mar 20, 2002 | 02:32 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Posi was not strong enough for my M6 02 Z28. Going with a spool, this should solve my rear end problems. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Coach 02Z28 M6 Drag Racer <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Mods: There coming real soon <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
<small>[ March 20, 2002, 02:33 PM: Message edited by: Coach 02Z28 ]</small>
Old Mar 20, 2002 | 03:06 PM
1madss's Avatar
Sorry, but the only thing that is not made by Moser in their rears in the bearings, gears, and the Posi. The axles and the housings are made Moser. The bearings are made by Green Bearings, the posi's are Auburn or Eaton.
I'm fairly happy with mine. I have had problems with leaking at every piece that I did not personaly assemble. But I have taken care of that. I did have and wheel bearing fail after about 8 months, which I thought was a little early, but that had been about it. Now their tech support leaves a little to be desired. have yet to call them with a question that seemed to me to be a pretty simple question for someone that built the damn thing. I've asked, what size tool is needed to remove the factory fill plug, how much fluid does it hold, what is the part number for the wheel bearing.
Mark
Old Mar 20, 2002 | 03:10 PM
onfire's Avatar
Coal Mining Director
I've had a Strange (first) then a Moser....IMHO both are strong diffs when setup properly..33spline,etc...BOTH companies are hit/miss on their ring gear pinion setup...My new Strange HOWLED and I took it out...I had the Moser blueprinted but it still makes a slight whine at 60-70mph...not bad but not OEM either...Until someone makes an OEM quality ring gear/pinion it will never be perfect on a consistent basis.
Old Mar 20, 2002 | 04:02 PM
Dean98TA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Phil99TAsoon:
<strong>Are you sure about that? I'm pretty sure Strange 12 bolts use Strange axles (although axles seem to be the only bulletproof part in the Moser so far) and Auburn posi's instead of the Eaton</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, that is right, Moser also uses their own axles, but I've never heard of anyone having a problem with the axles on any brand of 12-bolt.
My Moser came with an Eaton posi, which is just as durable as Auburn or any other posi. In fact, most after-market posi manufacturers do not even make the posi housing, they just rebuild the internals with their own spider gears, springs and clutch packs.
And as for the gears, believe it or not, my Moser came with Strange gears. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 21, 2002 | 12:40 AM
FastAl's Avatar
I've got a Moser on order and am looking forward to it! A friend of mine got a Moser last summer and beat on it from day 1. It was installed late one night, the following day a group of us drove about 500 miles to Kearney and raced the next day. His does have some gear whine, but what do you expect when you break it in on the highway <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
